jonstaley89
- Feb 19, 2013
Your problem is high HC at idle indicting an ign. miss fire. This can be caused by a number of things, Coil pack, wires, plugs, 02 sensor, engine wear, wrong chip etc. Although the standards are pretty loose in your state you still need a healthy cat to pass. But I wouldn't rush to do that till all the rest of the components mentioned are verified to be in good working order or you will destroy the cat very quickly. Even though you hate to spend money the benefit besides clean air will be a smoother running car which I'm willing to bet it isn't right now.
Go for the coil pack first, Check with ohm meter across the terminals. It has three separate coils joined together a good coil typically ohms out at 1150 to 1300 & they all should be I would say within 25 ohms of one another. The average life span is about 50,000 miles. the other most common is plug wires. Plugs should be R43TS gaped at .030. You also shouldn't ignore any check engine light or codes problem.Lol well you would be right. She isnt running strong, besides the volts problem she has a miss while in idle. I was going to replace plugs and wires either way.
The visual I have no idea what he seen, and there should of been nothing that I seen. Gas cap makes sense and isnt big deal. Cats will have to be put on there eventually. Im running rich at idle which I understand could be alot of diffrent things plugs, wires. Another question I got for you guys is. What plugs and wires should I run? Also Im thinking the car could use a tune to help fix this rich problem. I called a tune guy today and he said he had no software and stuff to do it, but he would do it if I brought it.
So the question is to tune what do I need? And what is the connector for the GN to see this?
