new parts for yall to critique.
dragonational
That Guy
this is the part list that i want to put im my new motor/car. any input would be great. Anything else you can think of feel free to add it. Harry
Engine Parts. Price
ARP HEAD BOLT KIT - STOCK IRON HEADS 49.00
ARP MAIN STUD KIT 52.00
ARP ROD BOLT SET - STOCK RODS $89.00
BILLET CENTER MAIN CAPS 148.00
BILLET FRONT MAIN CAP 75.00
BILLET REAR MAIN CAP $239.00
BRASS FREEZE PLUGS. 11.50
CAM BEARING SET 16.00
CORK OIL PAN GASKET 18.00
CORK VALVE COVER GASKET 12.00
MAIN BEARING SET 37.00
NEOPRENE REAR MAIN SEAL 13.49
ROD BEARING SET 26.00
ROLLER CAM BUTTON 10.00
ROLLMASTER TIMING CHAINS 119.00
STOCK INTAKE GASKET 26.00
Transmission Price
TORQUE CONVERTER ORANGE BRAWLER 3000 stall 315.00
TRANS COOLER 59.00
AC DELCO TCC SOLENOID 69.00
Fuel Delivery Price
FUEL INJECTORS 42.5 LB - 009's 46.50 each (6)
AC DELCO FUEL FILTER 14.95
FUEL FEED LINE- STAINLESS STEEL 95.00
FUEL RETURN LINE- STAINLESS STEEL 95.00
Suspension Price
AIR BAG – DOUBLE 69.00
PINION SNUBBER 29.00
Rearend Parts Price
AXLES - MOSER FORGED STEEL - STOCK REPLACEMENTS 219.00
Grand Total= 1952.44
parts
Use the stock rod bolts over if you know that they have not been cycled many times. Go with head studs instead of bolts. The 2 center billet caps are more than enough.
For injectors I would suggest going ahead and getting the 60#ers. Should be more than enough capacity than you will ever need. HTH.
parts
Scratch the pinion snubber!!! Gross waste of time and money.
Moser stock replacement axles (28 spline)---overated!!!! Stick with stock or move up to 31's.
