whats up guys...having a lil problem lately with the buick but what else is new
...here it goes....
start up in the morning and it has a rough idle....back out of the driveway and a very bad bog,miss and tip in stumble on a very light acceleration....get to the corner which is about a 100 feet and all is well...it will idle smooth..iac at 23-25 when she warms up...drive it too work...20 miles and perfect no stumble or miss...shut her down..sit for 15 too 20 minutes and start her up too park in the lot by work and it idles like crap...misses...almost stalls....bucks like a bronco...rev it up a few and all is well..no stumble or stall...but idles a lil bit rougher than i would like..postons 107 cam..i dont think the duration is that large to idle the way she does..i check fuel pressure and heres what i have so far...holds for 20 minutes then falls to zero...i pinch off return line and feed line to isolate injectors and holds fine so i dont think inj are leaking down and i dont think the return side is the problem..i pinch return line and pressure holds...so what do you guys think....sorry for so long and thanks in advance..vinny
