New PTS TC Solenoid, but no install directions?
  • Thread starter Thread starter GTEATER
  • Start date Start date
G
GTEATER
Guest
Has anyone got the install info or directions for these, I don't want to wire it backwards. There is also a brass fitting, and shims that I don't know what to do with.
ok...
Shims go under solenoid to case as it is longer and needs to be shimmed. Second..... red wire to red wire.....then ... Black wire to black wire. Somehow I thought it was self explanatory. Guess I was wrong......:D Hehehe BT
I'm sure that it would have clicked and been self evident if I was under the tranny looking at it before I ask. I saw where the diodes could be knocked out if wired backwards, so I wanted to have all the info before I started the teardown. Sorry to be a dumb f, but better safe than sorry.
On a side note, what would cause the tc not to lock after the tranny gets hot? Car has FAST and has manuel lock switch.
Not at all. I was just having fun. Actually it is very easy. And.... I KNOW you can do it. No big deal....BT
you know exactly what to do with the shims down at the gaybar, don't ya'!
I sure do...I'll need to shim your bunghole if I plan to keep pimping you out down there. Those boys have ridden you hard but you just keep puttin out. I know that I don't tell you enough, but your one GREAT biotch. If I could just get you to leave your boyfriend and move to San Fan...I'd make a killing off you. Your dad told me that gay prostitutes were in high demand there.
I the future please keep your gay chat out of my Tech post. Try www.buttpirate.com, I'm sure they will shoot the s with you idiotboy.
Pretty good cut and paste:rolleyes: Mike's arm on my body...lacks imagination, but what else should we expect from a known gerbil molestor
Thats right guys, no naked pict of girls...just a lonely boy trying to build a picture library of "guy on guy" shots. I know you like the model good looks that Mike and I have, but do the TB world a favor and stay in the closet a little longer:eek:
Are you guys friends or lovers?
