New Scanmaster numbers
moyersgn
I have a stock 86 GN. Installed a scanmaster last week. The numbers at idle were high. These are the new numbers after adjusting the tps.
BL at 150 is too high , it is adding fuel for some reason , could be a vacuum leak some where , tps is fine that is where I run mine
Where are you located? Coolant and air temps seem high for this time of yr.
In addition to above , are the 02's moving around?
