I just recently installed a TA49 on my car along with an SMC kit at the same time. Although I dont usually like to make more than 1 mod at a time, I had the opportunity and the time to do it. I thought what the heck.
Anyways, I kept my JL 93 street chip (20 degrees of timing) for my 30's. I have been gradually raising the boost and playing with the pump speed and the turn on point. At 19lbs of boost I would get no KR. AT 20-21lbs, I have seen approx 2 in most frames on the Scanmaster and as high as 4.9 today in 2nd gear. I get no KR in 3rd, even at the top of the gear. My O2's are pretty consistant in the low 800's now. I have not played around with fuel pressure yet. My concerns are for one, I do noit like to see any KR when running boost over 20lbs. My 2nd concern is I am running the pump speed at MAX right now and cant get rid of it. I hear of other guys running upwards of 25lbs of boost on high timing chips on pump gas with no KR. Am I missing something here? Should I pull timing out of it or add more fuel? I know my 30lb injectors will soon reach their max, but at this time I am not seeing that. It just doesnt make any sense that I would get the KR in the lower gears and not in 3rd......which would be the highest load gear.
To add another variable, I just added Race Jace's Power Plate to the mix and it didnt make any difference as far as KR suppresion.
If anything, it feels slower by the seat of the pants.
Any help would be greatly appreciated. TIA
