Tig Masters LLC
ATTENTION TO DETAIL
- Jul 13, 2007
Tig Masters LLC is proud to introduce our latest exhaust system product for the 1986-'87 Buick Turbo Regals including the '87 GNX.
Street Heat 3" Downpipe kit
100% Made in the USA, utilizing 304 Stainless Steel 3" OD mandrel bent tubing. This pipe has been specifically designed for use on 1986-'87 Buick V6 Turbo engines, when running Stock OEM or aftermarket Poston headers. This downpipe is currently the only downpipe on the market that was specifically designed to clear and match perfectly to turbos that are equipped with the GTQ turbine wheel. Previous downpipes in the past have a lip that hangs over into the exhaust stream and causes extreme turbulence and back pressure issues. This lip would require the end user to have to grind and port the flange when running a GTQ equipped turbocharger. Not anymore! Our downpipe was designed to be the highest flowing 3" downpipe on the market. With very close attention to detail paid to proper fitment when installed on the car. The pipe kit will include a matching 3" dump pipe with block off cap, grade 8 bolts with wing nuts and lock washers, Stainless Steel lap joint style band clamp and Stainless Steel hex head cap bolts with washers and a hex wrench. The downpipe is also compatible with either a 3" catalytic converter, Terry Houston dump pipe or an ATR dump pipe that has an overall length of 12.5" from end to end. Note: Dump pipe included in the kit is for Off Road Use Only and not intended for Highway Use.
Price for the kit is $450.00 plus shipping and handling.
Price for the downpipe alone is $365.00 plus shipping and handling.
For more information about our company and this exciting new product, please visit our website.
Thanks for viewing and let us know if we can help.
