Hi Razor Me Again, Installed The Kit All Day Wednesday Finally Got It Together About 11:30 That Night Shouldve Kicked Myself For Being So Easy Now That I Look Back I Can Do It Half The Time Next Time,
Any Way Heres My Problem Finished Every Thing Got To The Last Page To Do My Checks Ok 1) Switched Ignition On..... Low Led Was Bright Red With No Alch In Tank --Good
2) Remote Box Led Light On-- Not As Bright But On.....
3) Push Test Mode The Power On Led Was Bright Red & Power Injec. Light Some What Green Lit Up-- Ok.... So Far So Good..
Dials Sat Like You Had Them Between 5&6 Which I Guess Would Be The 10 O Clock Position
4) Filled Alch Tank with meth Low Level Light Goes Out
Test Drive .... Eased Up To 4 & 5 Psi Boost Power On Led Flickers Til Bright Red.. Perfect I Stopped At 10 PSI Boost ,No Knock
It Was Gettin Late So I Went To Bed Left Every Thing Like It Was.
Today Its Day Light Try Every Thing Again. Couldnt See The Power On Led That Well But I Knew It Was Workin Because I Hit Test & It Lit Up Bright & Car Ran A Hair Rich 0.9 Deg Knock 824mv.
Turned Dial On Remote To #7 Boost To 15psi 1.1knock Retard But Went Away Quickly Mv 800 Still Cant See The Power On Led Light.
Boost To 19psi Mv796 Remote Dial Still On #7 2.2 Knock Retard But Went Away Quickly, Still Cant See The Power On Led. Pressed Test Could See It Bright & Red As Night.
So I Assumed Every Things Still Working So I Waited Till Night...... Boost At 22, Cold Out Side, Press Test, Good Eased Up To 4 Or 5 Psi Of Boost The Power Led Flickers Barely Red Eased Up To 10 Psi , Barely Red Again 15 Up To 20 No Knock But The Power On Led Still A Dim Red, I Thought It Was Suppose To Turn Green At This Point
So I Tried It Again Floored It To 22psi No Knock But The Power Inj Light Didnt Light Up This Time, Power On Flickered Dim Red No Green
So While It Was WOT After It Wouldnt Change I Hit The Test Button .... BOOM Bright Green, I Said Now Thats The Way Its Suppose To Work.
It Seems To Somewhat Be Sprayin Some Alch In Because before this set up No Way I Could Boost Past 17 Without Knock In The High 11 & 13 Deg.k.r
But My Problem Is With The Gas Pedal Its Not Making The Power On Led Turn Bright Red Like Last Night & The Green Is Definately Not Coming On That Way Unless I Press Test. My Map Sensor Is Getting 4.9 Volts With The Car Off But Ign. On. At The Gray Wire But Its Also Getting 4.9 At The Green Sensor Wire . I Didnt Bother Any Settings On The Pump, Or The Pac Controller Only The Remote Gain Knob , What Couldve Happen From Last Night Til Now Did A Gremlin Go Out And Bother Something Did I Miss Something. what should i check im close on this thing i just gotta get this figured out.
