Jan Larsson
- Nov 22, 2001
So most of you know I got the engine out of my TTA after the main bearings gone south ... and thrust bearing gone as well as I could move the crank in and out more than spec ...
Not sure about the cause for this but one thing that been pointed out to me is that possibly the torque converter balloned and pushed the crank forward causing premature wear on the thrust bearing. I have no idea if this is what happened or not but I would hat putting it all back together and have the same thing happen again. (block, crank etc been machined and I'm ready to put it all back together.
Would you recommend I get a new torque converter to be on the safe side?
