I installed a TA-49 on my 86 GN yesterday, and got everything bolted up. Pretty straight-forward. The worse thing was trying to get the oil supply line off at the block. What a pain. Anyway, what all do I need to do now as far as upgrades, mod's, to make sure this combo will work? I haven't driven the car yet. I've got the adj wastegate rod set to the same length as I had on the stock turbo, which was set at 10# boost. I'll start uping the boost a little at a time, and seeing how it does. Do I need the larger injectors, or is 36# enough? Do I need to do anything? Thanks.
