New turbo is on
BADINBLACK6
Bolted on the new TA 49 and it seems to be working fine but it seems to be boosting weird.
It builds boost real slow up to about 8# then spikes to 15-16 real fast. Is this normal for a TA 49 or is something wrong?TIA
No not normal, i would check the puck to see if its sealing ok.
Kevin
Mine spools instantly, 2800 stall, but the stock tranny should spool good also.
The round thingie thats inside your downpipe, it connects to the WG rod.
if thats not sealing the hole in the turbo, it will lag.
