new updated extender chip question?
ulose2av6
hello guys i just received my new extender chip. my blm are at one 160 at idle. how can i adjust for this and when i do the car starts to run like a dog? and it says my af reading is 2. when i swap out chip af goes to 6 and blm goes to 130. what shall i do?
injector type? Manufacturer?
fuel pressure?
chip number?
Did you ask the vendor you purchased from?
MAF type?
Translator version?
Translator settings?
datalogging equipment type?
PCV valve and/or checkvalve type?
Bob
i currently have 55lbs msd, 45lbs pressure line off,bsp35bof5(chip). I have not spoken with the vendor will monday. i currently am running t+ w/3.5in maf switches are on on off off. i use a scanmaster and have a delco pvc.
BLM is 160 at idle, what about driving down the road?
Any numbers engraved in the side of the injectors?
Low impedance injectors? Is the ECM modded?
how are the dials set in the translator?
i as well as a few others i know have the same issue with the extender chip.
it dosent have 160 BLMs anywhere but idle. normal driving it is fine.
the car idles well.
other than that, id say the extender has worked well for me.
they are low impendence injectors(msd) the computer is modded. All dials are set to zero. when i adjust the dial to richen up. the car runs like crap.
Anyway, high BLMs are not 'normal' with the extender or any chip.
There are a couple things to try.
I have had bad luck lately with PCV checkvalves, not the ATR kind, but the one that goes inline with the stock PCV. It caused intermittant high BLM's and funky idles on my car. I removed it and normal operation returned.
if the cruise blm is also high, you can add fuel to the chip via parameter 11.
You can set the base dial to 1 for a richer idle (to try to lower the idle BLM)
3.5" sensor, what part number? There are a couple different ones.
Lastly, the chip can be updated with more fuel at idle.
Bob
