analogkid455
- Jun 10, 2006
Hi all. Looks like a very good site with ample resources.
I just installed a performance built 2004R in a mid 12s 80 T/A. The problems are, the more throttle I give it the softer the shifts are. Shift points are fine. Also is it normal for it to lock up in 4th gear at only 1000rpm while cruising. Seems low to me. The most irritating thing is when I want to eccelerate from cruise ( locked up in 4th) it likes to hunt even with steady pressure on gas pedal. In order to stop it from doing that, I have to either give it aggressive throttle or very super light throttle. Sorry for the long post and hope you can help me.Thanks!
ERIK
ERIK
