Did you use the 12 to 21 pin harness off of ebay thats like 9.99 or so? I just did this conversion myself. I bought the harness off ebay where you solder it together yourself. It was missing one of the illumination wires that goes in to the factory 2 pin connection. You'll see that on the 21 pin harness you have an extra Orange wire that didn't match up to any of the other wires. Its the Illumination Dash Lights wire. What i did to not chop up the factory hardness was i pulled the pin out of the factory 2 pin connection, its the Brown one. The orange in the factory 2 pin harness is the power wire which matches up with the yellow in the 21 pin harness. Then i just crimped a small flat spade connector to the left over orange wire from the 21 pin connector and plugged it into the brown wire from the car. Taped it up and now everything works as it should. Prior to this the same thing happened, everything worked fine until i turned on the lights then the display went dark. Once i connected this wire, it dims correctly as it should. Hope that helps.!
