I am putting my 87 GN for sale or trade , I am thinking about buying new business and money is little bit short , shame on me I would sacrifice my babe for that but there might not be any other way , I need extra car so I would consider trades , older but reliable any brand , convertible would be ok since I moved to Florida from Illinois or base GN or T plus cash , now let’s talk about my car ,selling price is $30 k , I don’t think you can add anything else to this car to make it better ,that’s my opinion , it’s Florida car that I bought 2 years ago and brought it to Illinois ,car never seen snow or even rain and now it’s back in Florida so body has no rust ,about 75k on the car , car has working heat but AC needs recharge ,there is small leak somewhere I don’t use it ,don’t care but if you charge it will work 100 % , suspension is stock springs but 3 way adj. front shocks and QA1 adj. rear shocks ,adj. rear control arms and H&R sway /roll bar ,car sits on very new 15 inch tires with MT 275/60/15 in a back , you can see engine specs in my signature but …. Weber build 109 stroker with girdle ,just been refreshed and have not been raced yet this season , GN1 heads with 1.65 T&D rockers ,220/224 cam , 70mm Precision upper and TB on champion intake , Fast XFI and Fast XIM for ignition and coil on plug system ,two step and rev limiter ,trans lock with manual shift turbo 400 ,9.5 ART TC ,and custom drive shaft with loop and 9 inch Detroit Locker rear end , line lock ,Razor twin nozzle Alky , Apex boost control which you can sell off and control boost with Fast XFI ,ATR headers with external WG 3 inch DP with third muffler set up and dual 3 inch after that with pit-bulls ,double pamper with 83 LBS injectors , dual ball bearing GTQ 76 mm turbo , Fast 6 EGT probes alky and fuel pressure are loged into XFI ,Precision front mount IC , F body radiator with dual fans keeps the car cool all the time , vacuum brake conversion with dual piston calipers /disc in a back and oversized single piston and cross drilled rotors in the front make this car stop very well , Alston racing IL , 6 point roll bar approved to 10.0 , I include laptop computer with tunes and 5 gallon racing Alky with it , I also have brand new build all forged 109 /girdle short block that I will sell you with the car for $3500 , email me with any questions and for more pictures to gczarny@hotmail.com ……….. Some pics may show my car on 16 inch GNX wheels , they sold and car sits on 15 inch welds seen in two other pics on second page ,everything else same , has good alarm system and all around laser sensors/shifter with passport 9500, I am sure I did not cover everything so ask me by email ,car is located in Sarasota FL ,thanks
