I thought I would post this realization I recently had.
Using nitrous with methanol can net more or less power depending greatly on the temperature of the mixture during the compression cycle. Nitrous oxide used together with methanol yields a super cool intake charge. Since nitrous oxide must reach a certain temperature before it will dissociate into oxygen and nitrogen so that the oxygen can be used to burn fuel, if during the compression stroke some of the nitrous oxide has not dissociated, it will dissociate during the combustion process. Since the dissociation in itself absorbs heat, some of the combustion process heat will be absorbed affecting the resulting power level. The same holds true for the methanol fuel. There must be enough heat during the compression stroke to vaporize the methanol before the spark ignition event. I had read that some that had used methanol with nitrous experienced a horsepower level of about half of what the system was rated at, so I went with that assumption. I created a port injected nitrous system with a rating of 190 horsepower using the nitrous oxide jets as a reference. I have found that less than traditional ignition retard, while the nitrous system is activated, will have a great affect on the resulting power level. Possibly caused by creating more heat during the combustion process to overcome the heat lost by some of the nitrous oxide that is still dissociating during the combustion process.
