TurboTdr3.8
- Jan 15, 2013
My 2004r has working great and all of sudden it started not going to 1st gear at stops and goes to 2nd gear and sometimes it goes in like normal , I can manual shift when it does it in 1st gear and it works all the gears . I have checked the TV cable and it has not moved from its setting or binding , where else do I need to look ?
The shift pattern up and down works fine and no slipping in any gear and fluid is fine with no burnt smell and color is cherry red .
This trans has been built many years ago to the next level of stock like Stage ! and it shifts hard and firm nicely so I do not believe there is too much wrong inside the clutch areas but something sticking for some reason . I have not had gauge put on it either . Any ideas ?
