Tom Tom Turbo
Turbo Goes Woo Woo
- Jul 10, 2002
So I'm finally getting the car back on the road, but I have a few issues. First, I have no back up lamps...there is a black wire that goes to a small switch on the B&M Pro Stick, but it appears as though there are two switches that were mounted on the shifter. I have verified that bulbs are good and all of the other tail lights, turn signals, etc work properly.
Second, I can start the car in ANY gear and it makes no difference if the brake is depressed or not. I found a brown/orange wire coming out of the ECM that is cut and has another wire spliced into it, but I don't know if that is part of this issue or not.
If you need some pictures, I will try to get them posted. What typical things could cause these problems?
