I hope this is just the starter, but I have my doubts. I started my car and the IAC was jumping around 0 to 97, so I unplugged it and unwound the wires a little and then I noticed that my oil sending unit was unplugged from its connector. At that point I had to shut the car off and plug it back in once the car cooled a little. Scanmaster is working when the ignition is turned on and PL. The PL showed a EEPROM fault, however, I couldn't get the fault to set again. Maybe the ECM is crap, but it appears to be reading all the sensor inputs ok and displaying them on the PL and SM. The starter not even engaging, I can hear the click of a relay in the dash, but it won't turn over. So it is either the starter or the ECM or the TT chip. The code was a 51 and said the EEPROM maybe unplugged. If the limp home mode chip is faulted will it cause the same thing? Anyway, I have another ECM as a backup, I have tested it in my car before I bought the PL and I can try a different ECM and then starter or vice versa. I think I will try the starter first, then the ECM. After that, I will have to start checking the grounds and ohm out the harness. The joy of owning a Turbo Regal.
Any suggestions.
Any suggestions.
