Crammysauce!
- Feb 23, 2007
I installed my new motor, and everything seems to have gone really well. The only problem is that I'm not getting any fuel at all, and can't get the engine started. I checked the line at the fuel rail inlet, and it's dry as a bone. I have already changed the fuel pump relay and the 15A fuel injection fuse is good. I thought it might be the harness ground, so I checked it and it's okay too. I have yet to check the voltage at the pump, but besides that, is there anything else anyone can think of to check? I'm usually pretty good at troubleshooting, but this issue might have me stumped. Everything was working fine when the old motor came out. Are there any sensors that would keep the fuel pump from running? I didn't unplug anything that (at least not that I think) would affect the fuel pump electrical source at all. I don't get the initial cycle when you turn the key to "ON". Yes, there is gas in the tank. Any ideas?? Thanks, guys!
