Jul 15, 2005 #1 T TurboEd Member Joined May 24, 2001 Messages 136 i'm putting a 86T back together,i've have fuel pressure,but if i pull a plug they are drv?? help?
Jul 15, 2005 #2 F Fuelie600 Active Member Joined May 25, 2001 Messages 1,847 Injector harness plugged in? Is your ground good? Check your fuse? What have you checked so far? Brian
Jul 15, 2005 #3 T TurboEd Member Joined May 24, 2001 Messages 136 the injector harness is connected,grounds are good,fuses are good.changed the ecm off a running gn.sure use more idea's ed
Jul 16, 2005 #4 T TurboEd Member Joined May 24, 2001 Messages 136 HELP PLEASE the spark plugs are dry,no codes come up Thanks, ed
