Im running the Fast SEFI and have no IAC, 160 lbs per hr injectors. I cannot seem to obtain a satisfactory idle the motor has a very very large plenum space due tot he IC mounted directly to the top of the sheet metal manifold. The motor wants to surge slightly and if you tap the throttle it will die when the revs come back down. Cold start is not so great either. The motor in question is a 397 inch Twin Turboed V8. Ive drilled a very small hole in the TB it really seemed to help out alot. Im having to screw the throttle blade open too far to get a idle. Thanks
