Mike St. Louis
- Aug 1, 2016
Going down the rabbit hole... daily driver with usual mods- TT , injectors, alky, 340pump hot wire kit, 58/58.
Car was running great until it wasn't. Will randomly stall at red lights and stammer hard under throttle from stop.
IAC jumps from mid 70's to over a hundred and then stall. Sometimes it spikes rpms and recovers.
Numbers while hot in D with brakes
AF 05
L8 32-33
Int 128
Bl 122
Clt 200-204
Ats 95
Rpm 800-825
Tps. 42
Iac 75-82
No Mal's
Idle hot in park numbers:
Af 04
L8 28-30
Int 128
Bl 122
Clt 200-204
Ats 95
Rpm 800-825
Tps .42
Iac 37-45
No Mal's
Any help is greatly appreciated.
AF 05
L8 32-33
Int 128
Bl 122
Clt 200-204
Ats 95
Rpm 800-825
Tps. 42
Iac 75-82
No Mal's
Af 04
L8 28-30
Int 128
Bl 122
Clt 200-204
Ats 95
Rpm 800-825
Tps .42
Iac 37-45
No Mal's
