turbodiesel6_6
- Sep 30, 2008
Ok guys, i did some scan logging today and im hoping that someone will see something in the scan that i dont. I did notice that the knock was at 3 counts. Now before i started logging it and the car started warming up, i had a knock count of 21, so for some reason by the time i got the scanner hooked up, it went down to 3. So far this has been what has been done to it before i got the car, and obviously someone else tried to fix this same issue with no luck lol... theres new injectors and they are stock, it has the stock chip in it, and stock turbo. I did notice that the turbo is not spooling up either. I took the intake hose of and the wheel is very free, with no play up and down or side to side, all the hoses seem to be good, so i put a vacuum pump on the diaphram hose to the actuator on the turbo, and pumped it it to 13.5 psi and no arm movement. I proceeded to pump to 25 psi and still no arm movement, the only way i can get the arm to move is if i pull it towards the pass. fender. Im not for sure if this is part of the reason for my rough idle or not. Here is the scan data for some of you to look at... any ideas are greatly appreciated.... thank you in advance, and its an awesome site!!!!
