No reverse??
NEARING
I took my car out to wash it after I fixed the cam sensor( with some over the phone help from B Mason:o )
When I went to leave the store I found out I could back up,
Even in neutral the car would not roll back down the hill I was on,it was like it was in park, but when I turned te key off it started to roll back.
T-Brake,2nd,3rd, and OD are normal.
neutral is as described above.
reverse is like park
Park is like it is back in drive!!:confused:
I have not touched any linkage and I don't think even if I had loose linkage it would cause these problems?
This car is starting to get on my nerves:(
ANY ideas, HELP!:confused:
It'd help if you let us know who's Trans-Brake valve body you have since they are designed differently.
Stage right.
At least this is what I was told when I bought the car.
sounds like the forward clutch is stuck to the input ring gear .put the car in neutral or park and rev it up to see if it is trying to pull forward.also put it in neutral and try to push it .itll roll easily if the clutches arent locked .if it is hard to push in neutral with the engine running suspect a cross leak in valve body or gaskets.www.ckperformance.com second to none........
