SignUp Now!But it would start back up once it was cool right?Also had a similar situation after driving the car would warm up and then die out and no spark. Replaced the ignition module and coil pack and car ran great after that.
Yes would park for a hour or so and goodto go again until the module or coil pack heated up. Not sure which of the 2 was causing the problem so swapped them both out and all good now..But it would start back up once it was cool right?
Yep!Are you getting fuel pressure?
