No-Start Condition After Warm Up
MacedoMS
PMF Wizard
If you ever encounter a No-Start condition after warm up, check to ensure the Ignition Module is receiving the necessary 12v input from the Ignition Switch. Our problem child would crank cold and run fine, although almost every other time, she would not restart after warm up.
More info please......does it turn over, does it try to start, tell us about your car.
Turbo Ta no crank warm
My Turbo Ta always had a no crank condition only when hot and not very often. Replaced starter, transponder box, ignition lock (new transponder key) and even bypassed original starter wires and transponder wires. It still would happen every once in a great while. When I installed a Vette mini starter, it almost went away completly, but happened once on a 95deg day. Would love to hear if anyone else resolved this issue! My inclination would be that the starter was just heat soaking. It always started when it cooled down.
