turbowannabe
- Dec 6, 2001
Trying to get my project up and running and I can't get the damn thing to even try to start. Primed the oil pump and set the cam sensor using one of Caspers cam sensor tools. I've got spark, injector pulse and 40lbs of fuel pressure but the car will not start. I shot some carb cleaner directly into the intake with the throttle open, cranked her over and she fired and I immediately shut the key off.
I was starting to think that I didn't get the cam timed right, but wouldn't the car at least get fuel and fire every once in a while, or just run like complete crap? I also have a ATR pitbull chip for stock injectors but the car has Tomco D1720AA injectors which look to be 33lb injectors. Could having the wrong chip not let the car start? I'm stumed right now. I would re-time the cam but the cam tool I used is one a buddy of my let me borrow and I can't get it from him right now. Let me know what you think
thanks
-Dan
Forgot to mention that the car has a fuel cell with Aeromotive pump and lines. Still holds 40psi when cranking though.
thanks
-Dan
