I changed my head gaskets, timing chain to a double roller, push rods (had to go adjustable), and got my turbo rebuilt. I took the oil pump apart just to check to make sure it looked alright and put it back with new gaskets. I tried to prime it with a drill and really had no luck. So yesterday I went to crank for psi and again had no luck I took the oil feed line off and waited to see if oil would came out and nothing I cranked for about 30 seconds. I also packed the pump with vasoiline before I primed with drill. Now the thing is the car won't start I have spark and fuel I was thinking that the oil psi safety was causing somthing not to work because I can't get no oil psi. I also took off the oil filter and tried to crank to see if oil would come out. I'am thinking of getting a new oil pump and try priming it with a drill again. I really don't think that the the oil safety is casuing the no start. Right now I have it all back apart so I'am going to replace the pump and go from there. Any help is greatful.
Thanks,Dave
Thanks,Dave
