OSCAR'S GN
- Dec 10, 2008
I have a problem with my 87gn. One day the car just did not start anymore. when i tried to start it,My dash started to flicker, also my knock gauge started flasing. The car would not crank. some ticking noises from the fuel pump relay area and under my powermaster when i would try to start it up?? Also it had no fuel pressure?? new battery.I check the fuses, its ok, replace the relay, still nothing, replace new walbro pump, still nothing, and still no fuel pressure.Checked all connections. I prime pump with connector behind alt. I hear the pump click only. Did it with fuel pump hotwire connected. Hooked it up to turbolink also ... no codes. Even checked if my starter was good. turns out it still good. After all this still no fuel pressure, but no more clicking, and starter clicks when ever i try starting her up.
Need help please!!
Need help please!!
