Hi all:
I have an 87 TR. It is virtually all stock, and typically runs great. It is a daily driver, and I have not really had any problems with it. I parked it for about 3 days last week to drive my wifes car because her car was having some problems I wanted to check out. Her car finally died Saturday, so we all hoped in the Buick to go to dinner, and no start. It was running fine when parked.
It cranks fine and has spark, but I am not getting injector pulse on a noid light. Fuel pump is working, but injectors are not getting signal to fire. I suspect the cam sensor, but am not certain. How can I check the sensor to confirm? I have read all the info on how to change the sensor, but have not seen anything on how to check it to confirm this is the problem.
Also, if this is the problem, can just the cap be replaced, or does the whole sensor need changed, and, will pulling it out and resetting it do the trick or are they just dead when they go?
Any ideas/info/how to check sensor would be appreciated.
Thanks all!
Thanks all!
