Jun 21, 2004 #1 S spins4 New Member Joined Jul 29, 2002 Messages 53 Just wanted to see how much boost you guys are running with ALKY and no intercooler? Also, what octane? And what MPH has the car run if applicable? If you could describe how much your sys flows (nozzles, pump) that would be great too. Thanks guys.
Jun 21, 2004 #2 B bruce Rest In Peace Joined May 25, 2001 Messages 10,367 I relocated my AIT sensor into the plenum, so I could take some meaningful temps.. Here's the logs and info.. http://www.t6p.com/forums/showthread.php?t=1991 Using a Syclone ecm, I can run 25 PSI on a hot summers day and not even need the alky, but with alky returns the preformance to like on a fall day.
Jun 21, 2004 #3 S spins4 New Member Joined Jul 29, 2002 Messages 53 Bruce, thanks for the hard data! What octane are you using for 25psi with no intercooler and no alky??? That is crazy! I just want to squirt some Methanol, and go for 25psi on a racegas/pumpgas mix or even full racegas with no alky.
