Not downshifting into 1st.
1nadrag
Ok I finally got my car to shift after having it rebuilt. The idiots didn't put any check balls in the valve body.DUMBA$$ SHOP! Now the only problem I am having now is that it will not downshift into fisrt when I come to a stop. I can put in first manually. Also when I am stopped I can shift it from 1st to 2nd without moving and I can feel it change gears. Any opinions? I think it has to do with something in the valvebody but not sure.
Thanks Tom
Did they put in a new tcc solenoid. When mine went bad the downshift to 1st was erratic. Just a thought??
I put a new one in last year. But it could be bad. Any other suggestions?
Hey Mark:
If the band is too tight, would or could that cause a slip in reverse?
1nadrag:
Is your reverse working OK?
Are you having second gear starts in OD? What is your line pressure in OD with the TV cable hooked and unhooked at 1000
RPM?
