72firebird
- May 18, 2004
Well I finally got my TTA back together. I put a PT51, Protorque 3000 stall l/u, transmission built by Janis Transmissions, 009 injectors, Walboro 340 hotwired from Racetronix, and a 100 octane chip from TurboTweak. I took the car out for the last 2 days and drove around a bunch to break the transmission in. Whenever I finally got the mileage that Janis suggested I tried really getting on it. The chip says it's for 24 psi but according to my stock boost guage (yeah I know it's not accurate but it's a little more accurate than this) it showed about 11-14 psi. The car seems to pull pretty hard but I know it has a bunch left in it. The wastegate that I put on has an adjustable rod but I made it the same length as stock. It felt like it might have had a little bit harder spring but that would make it boost more. What would my problem possibly be?
My next problem is my Turbolink won't connect with my OBDI port. It worked last year when the car was stock. It connected once last night for like 3 seconds the light was on the port connector but then it went off. Ever since then it hasn't worked. I have no idea why it wouldn't be working but if anyone has any ideas I would love to hear them because I have checked everything I could possibly think of.
