Ok, here's the deal, i just recently put blue tops in with a thrasher 92 chip for them
If i'm part throttle under 2K RPM's i'll be in closed loop(the O2's bounce around like they should) but anything over that they O2's stay around 850+!
I really need help guys, i didn't have this problem with the stock injectors and Thrasher chip
I'm getting around 10 MPG with only 42#'s of FP line off, i have an AFPR on its way, also i'm only getting like 13#'s of boost, i have to figure that out now too
but it seems i'm entering open loop when over 2K RPM's..i can't have this, 10 MPG is unacceptable
TPS is a smooth increase, .42-.44 at idle, IAC seems ok...i hit open loop at idle which i'm suppose to. O2 has like 4K miles on it, i'm about to just get a heated one...anyone have ANY ideas?????
thanks guys!
thanks guys!
