9
But it's ALL my fault!
If you're not ready to race don't race! I wasn't.
Filled up the tank 50/50 and left for the track, played and tried to dial it in on the way
Got to the track sort of late and changed tires, ran with 22psi in the QTP's (I was feeling lazy so I didn't want to change back before I left so I left a lot of air in the tires).
1st pass pump speed MAX and turn on point? as it came. 20 psi boost
60 ft 2.1 BAD bog!
12.28&113.94
slowest car has Ever went!
A couple other GN guys were there with Bobby Mason that had alky, Wayne I think was his name took a look
at my alky setting and turned my pump speed down to 7.5 and raised the turn on point a bit.
Raised boost to 22.
60ft 2.05 bogged then spun
11.96@119.85 hit rev limmiter in 2nd too
I will have my s*@* together next time out!
60 ft 2.1 BAD bog!
12.28&113.94
Raised boost to 22.
