I am getting a little confused,the plan was to slowly turn up the boost until I see knock, then back it up a little, then make fuel adjustments in the chip if needed. I am controlling the boost with the factory setup with a standard adjustable actuator.The waste gate bypass hole is ported to .960.I have 3 PowerLogger files,why is timing being pulled in LogFile 9 and 11, when all I did was increase boost by a 1/2 turn in each to help lean it out a little.Thanks for your help,ikle.
