usetaboost
SAY CAR RAMROD!!
- May 4, 2005
well not total crap, but it ain't better. replaced everything and it seemed like it had LESS power. Yes I did check the gaps, all 60. All of the old plug wires had cracks or gouges. Don't understand why it would have less power. I decided to check the timing after it warmed up. for some reason it was 3 degrees advanced so I dropped it down to 15. seemed to miss a little. unhooked the battery, plugged the connector back in, hooked up battery. I noticed it seems to kind of fall on its face when it shift gears if I granny it. Could there be a carb problem? Why would it run worse with the correct timing? I'll double check the firing order and vacuum hoses but I'm sure its all right.
