O2 Replcement Tips
GN632
87 Gn O2 Any Tips As Far As Removing O2? How Hot Should Area Be When Loosening O2, Do Not Want To Strip Threads. Thanks
Just give it a try first, you might be surprised. I changed my 02 over the winter and thought for sure it would be stuck, but it came right out, without heat.
Run the engine for 45 seconds to 1 minute, then use a 7/8 in. wrench to spin it off. Depending on how long the sensor has been in place, you may have difficulty removing it without heat.
Use nickel-based anti-seize lubricant on the threads of the new sensor if it doesn't have it already.
What they said above and use a Denso o2 sensor, they're half the cost of a normal one and are filtered.
