A little about my car first. 87 GN with 37k miles on it. Mods- Walbro 340 with hotwire, afpr, k & n cone, 30/30 boost gauge, Caspers knock gauge, scanmaster 2.1, ATR 2.5 SS exhaust, gutted cat, Poston 3" DP, Postons driver side header, Hi-Effieciency radiator, 160 stat, fuel pressure gauge, completed all Spring cleaning procedure within last 600 miles. Here is my problem. Took the car out today and was crusing about 30-35 mph, nailed the gas, and my knock gauge lit up to the 2nd amber light and the scanmaster showed a max 6.3 kr. When I get on the gas gradual, I get no knock, but wot from a stand still or from a roll, it's starting to knock. This hasn't been the case in the past. Running 16-17 psi, 42 off-line fuel pressure, and had been getting no knock. I took the car to have the rear main replaced and had regular oil put back in besides synthetic. I was running synthetic before, but this shouldn't give me knock should it? Also, I was told that my crossover pipe is not sealing up like it should. So, I'm leaking exhaust from the crossover because I have not installed the passenger side header yet, its still stock. Will this cause knock? These are the only things I can think of that could be casuing this. Let me get some input from you guys. Have to get this knock outta here. Sorry for the long post, didn't want to leave anything out, or at least tried no too.
Thanks.
Brad
Brad
