1.542 60' and 125.8mph thats an easy 10.60 to 10.70 time slip. The killer is the 7.072 @ 96.42mph in the 1/8.
1.542 60': stock suspension doesn't seam to be holding you back none.
125.8mph: pump gas isn't holding you back any either.
Now here is my question and it pertains to a few cars and not just yours: If you have enough HP to hit 126 mph in the quarter, and if you've put the power to the ground good enough to cut good 60' times, then what the heck keeps the car from running the good 1/8th mile ET and MPH? The only times I've ever seen a good 60' time give the big ET gain in the 1/4 is when that 60' time was backed up with good 1/8th mile ET and MPH.
Maybe you'll be like I was when I tried to get an 11 second pass. The first time I got my original set up into the 11's it was an 11.30. I tried a couple of times to get an 11.99 and it didn't happen, and then wam! 11.30. Don't feel too bad about the 11.99 though because after dumping a few more grand into the car I finally got my 11.99 pass!
DR Boost made SEVERAL 11 second passes looking for that first 10.99. When he got that first 10 second time slip it was a 10.6 second pass with a
1.55 or so 60' time and 126 mph in the quarter , that 60' and mph sounds familiar.........
Keep up the good work man, the 10.xx is going to happen. How low the XX part will be is the only question.
Jason
