Well after checking my turbo for oil I found my pvc valve,hose leading up to the vacume block wet with motor oil.What actions are you guys doing? I removed the vacume line from the valve & hooked up my brake booster to that line.Left the valve in place.My gess is a breather on the left valve cover is next.Any advantage to removing the breather tube to the turbo inlet? Thanks,tom
