oil capacity??
it should be around 6 with a pf52 filter, 5 with the stock pf47. i use the biggie filter adapter with a pf24 and i use 6.5 quarts.......
NO WAY HOSIE that a pf-52 takes a quart more!!!
IT may be 5-8 ounces of oil more TOPS
TAKE A LOOK AT A PF47 , THEN TAKE A LOOK AT A PF52, THEN TAKE A LOOK AT A QUART OF OIL<
POUR IN OIL UNTIL THE DIP STICK SHOWS THE CORRECT LEVEL
i know it doesnt look like it, but i know with a pf52 the car takes 6 quarts, maybe a 47 is 5.5????
I just put in about 5 & 1/3 ( that's about all I ever use )with a PF52 and the dipstick reads near the top of the "full" area. I even let the car down off the jackstands to drain so I think I got as much old oil out as I could. My driveway is slightly sloped so I'll double check the level at work on Monday but I'm sure it's good
