Alright I have what everyone says around here is , A BIG PROBLEM. My very modded GN goes through a quart of oil about every 100 miles (highway or cruising miles doesnt matter). Here are the things that are the problem and things that have been looked at.
Thought it could have been a bad turbo seal but there seems to be no oil residue in the intercooler or throttle body.
Motor has been leak checked, Seals checked, and compression test checked (#'s on compression test, Cylinder #1 150psi, #2 160psi, #3 155psi, #4 150psi, #5 155psi, #6 150psi) by respectable GM Mechanic (Mechanic says engine is very sound).
So what could eat a quart of oil every 100 miles?
