Oil Cooler Location? Under Fender/Side of Radiator
Blown&Injected
So what do you all think? It is an Earls Temp-a-Cure or something like that, about 12x3x1.5 with -8 fittings.
It looks like it will fit under the battery next to the radiator. Thinking about just welding a bracket to the frame. About the same place on the drivers side could work too.
Car has a FMIC and a B&M trans cooler mounted on the radiator support - bottom center, just peeking out from under the license plate or I would put the oil cooler there.
Any ideas and or pics would be appreciated - I only looked for a few minutes before those areas I mentioned jumped out at me.
TIA
don't have pics but I did a few cars like that.. plenty of room there :cool:
