Jun 22, 2006 #1 B BEATBY6 Member Joined May 28, 2001 Messages 628 Does anyone have a source for all the o-rings and the copper crush washer for the oil cooler setup on a TTA?? I'm putting one together that has all bad ones and missing the copper washer.Thanks alot,Scott
Jun 24, 2006 #2 J Jan Larsson Active Member Joined Nov 22, 2001 Messages 2,151 Johnsperformance.com carries one of the o-rings. The flat o-ring between the two flat parts you can use the o-ring off a oil filter. The copper washer John might have as well but I can give you some dimensions as I just took mine off my engine this morning ...
