oil drain for New turbos
Clark6
Will the new ceramic bb air cooled center section turbos (6265)
Will the factory oil drain tube work on this?
Also will the factory oil feed line work on this?
I know in Pats introduction it says recommended is 4Ans but I have 3Ans 1/8th npt. Is there absolutely No way I could this this to work or will I have to buy all New different entrances & exits?
Those that have this turbo what did you do , change all of this or stay the same?
I'm debating on getting this turbo to replace my 6776. (blew center seal after 3yrs???)
stock drain is fine. The DBB turbos use very little oil anyway. The oil feed is like a pin hole.
