Jun 30, 2002 #1 8 8scbuick New Member Joined Jun 8, 2002 Messages 51 When running a twin turbo car.Can you run the drains from the turbos to the dry sump pump or will the pump suck to much oil from the turbo. Tony.
Jul 2, 2002 #2 C cogdrive New Member Joined Jun 14, 2002 Messages 20 I run a vented vortech blower and still won't run the drain into the pump, if for no other reason, smoke a bearing - hurt the pump. Hope this helps.
