Just recently bought this car and, unfortunately, the previous "hands" in it had no right being there. Been nothing but un-screwing what they screwed up the past couple of weeks.
Anyway, it's been smoking intermittently. Sometimes barely any at all, other times, it just billows out the exhaust. Seems worse after idling a while. The intake was covered in oil when I pulled the dog house, and when I wenter to check the bolt torque, it was extremely loose. Assuming that was my problem, I put a new intake gasket in, cleaned everything up and reassembled it leaving the pcv disconnected (has breathers in the ds valve cover). After driving it a bit, it seemed ok until I let it idle a while and it started smoking out of the exhaust again. I was hoping it was turbo seals but not looking that way. I pulled the dog house again last night and the lower intake is nearly dripping with oil again. Dog house, throttle body, upper pipe, etc. are all dry.
Im thinking it is either intake valve seals/guides or possibly intake gasket not sealing properly. I know the heads are ported from a visual i spection, but know nothing about them. Is it possible for them to be milled too much, causing sealing issues? I assumed if it was an intake sealing issue, it would be leaking coolant internally also? The car also has a decent amount of blowby (steady even smoke out of the breather with the pcv disconnected, not puffs like I've seen with one or two damaged pistons). Is it possible for it to even get past the rings and up into the intake or am I definitely looking at a top end issue?
Sorry this got so long, trying to be as descriptive as I can. Thanks.
Joe
Joe
