bad oil leak from below the oil pump. Tried every thing , could not find it. The bolt that holds the intercooler bracket is leaking. It was tight but appears to be leaking out around the threads.
That bolt is a blind hole. Most likely a gasket or hairline crack in the cover..ask me how I know. Always use thread sealer on the other cover bolts as they going into the crankcase and coolant.
